cluster peer ping
Initiate intercluster connectivity test
The cluster peer ping command displays the status of the network mesh used by the peering relationship. The command checks the network connection to each remote IP address known by the cluster. This includes all intercluster addresses. It is possible for a known address to be not present during the ping. These addresses are not checked, but the absence is temporary.
The most useful parameters for diagnosing problems are -count and -packet-size . Use the -count and -packet-size parameters to diagnose problems similarly to how you use them with the standard ping utility.
To display network connection status within a cluster, use the network ping command.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-originating-node {<nodename>|local}]- Node that Initiates Ping-
Use this parameter to send the ping from the node you specify.
[-destination-cluster <Cluster name>]- Cluster to Ping-
Use this parameter to specify the peer cluster you wish to ping.
[-destination-node <Peer Node Name>]- Node to Ping in Destination Cluster-
Use this parameter to specify a specific node in the destination cluster to ping.
[-ip-address <IP Address>]- Active IP Address-
Use this parameter to specify the active IP address you wish to ping.
[-count <integer>]- Ping Count-
Use this parameter to specify the number of requests to be sent to the destination.
[-status {unknown_node|internal_error|unreachable|session_reachable|interface_reachable}]- Status of Ping Operation-
Use this parameter to display only ping results that have the status you specify.
[-timeout <integer>]- Ping Timeout in Seconds-
Use this parameter to specify a timeout value in seconds for the ping operation.
[-packet-size <integer>]- Size of Packet-
Use this parameter to specify the number of data bytes to be sent in the ping packet.
[-ttl <integer>]- Time to Live/ Number of Hops-
Use this parameter to specify the maximum number of network hops a packet may make before it is considered a failure.
[-response-time <double>]- Response Time (ms)-
Use this parameter to display only nodes that have the response time (in milliseconds) that you specify. This parameter is most useful when specified with a range of values, such as
>500
This example shows a ping of cluster1 and cluster2 from cluster2. All nodes are reachable.
cluster2::> cluster peer ping Node: node1 Destination Cluster: cluster2 Destination Node IP Address Count TTL RTT(ms) Status ---------------- ---------------- ----- ---- ------- ------------------------- node1 10.98.228.230 1 255 0.209 interface_reachable node2 10.98.228.234 1 255 0.42 interface_reachable Node: node2 Destination Cluster: cluster2 Destination Node IP Address Count TTL RTT(ms) Status ---------------- ---------------- ----- ---- ------- ------------------------- node1 10.98.228.230 1 255 0.358 interface_reachable node2 10.98.228.234 1 255 0.17 interface_reachable Node: node1 Destination Cluster: cluster1 Destination Node IP Address Count TTL RTT(ms) Status ---------------- ---------------- ----- ---- ------- ------------------------- node3 10.98.229.22 1 255 0.336 interface_reachable node4 10.98.229.29 1 255 0.354 interface_reachable Node: node2 Destination Cluster: cluster1 Destination Node IP Address Count TTL RTT(ms) Status ---------------- ---------------- ----- ---- ------- ------------------------- node3 10.98.229.22 1 255 0.354 interface_reachable node4 10.98.229.29 1 255 0.336 interface_reachable 6 entries were displayed.
