template rename
Rename a template
Use this command to rename an existing template.
-name <template name> - Name of the template
This parameter specifies the name of the template.
-new-name <template name> - New name of the template
This parameter specifies the template’s new name.
The following example renames a template template1 as template2:
cluster1::> template rename -name template1 -new-name template2
