ONTAP 9.7 commands
snaplock log delete
Delete audit log configuration for a Vserver.
The snaplock log delete command deletes the SnapLock log configuration associated with the Vserver. This command closes all the active log files in the log volume and mark the volume as disabled for SnapLock logging.
-vserver <vserver name> - Vserver Name
Specifies the name of the Vserver whose SnapLock log configuration is deleted.
cluster1::> snaplock log delete -vserver vs1
        [Job 47] Job succeeded: SnapLock log deleted for Vserver "vs1".
