security certificate truststore show
Display default truststore certificates
This command displays information about the default CA certificates that come pre-installed with Data ONTAP. Some details are displayed only when you use the command with the -instance parameter.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Name of Vserver
Selects the Vserver whose digital certificates you want to display.
- [-common-name <FQDN or Custom Common Name>]- FQDN or Custom Common Name
Selects the certificates that match this parameter value.
- [-serial <text>]- Serial Number of Certificate
- [-ca <text>]- Certificate Authority
- [-type <type of certificate>]- Type of Certificate
- [-subtype <kmip-cert>]- (DEPRECATED)-Certificate Subtype
Selects the certificate subtype that matches the specified value. The valid values are as follows: -
kmip-cert- this is a Key Management Interoperability Protocol (KMIP) certificate
- [-cert-name <text>]- Unique Certificate Name
This specifies the system's internal identifier for the certificate. It is unique within a Vserver.
- [-size <size of requested certificate in bits>]- Size of Requested Certificate in Bits
- [-start <Date>]- Certificate Start Date
- [-expiration <Date>]- Certificate Expiration Date
- [-public-cert <certificate>]- Public Key Certificate
- [-country <text>]- Country Name
- [-state <text>]- State or Province Name
- [-locality <text>]- Locality Name
- [-organization <text>]- Organization Name
- [-unit <text>]- Organization Unit
- [-email-addr <mail address>]- Contact Administrator's Email Address
- [-protocol <protocol>]- Protocol
- [-hash-function <hashing function>]- Hashing Function
- [-self-signed {true|false}]- Self-Signed Certificate
- [-is-root {true|false}]- Is Root CA Certificate?
The examples below display information about the pre-installed truststore digital certificates.
cluster1::> security certificate truststore show
Vserver    Serial Number   Certificate Name                          Type
vs0        4F4E4D7B         `_www.example.com_`         server-ca
    Certificate Authority:  `_www.example.com_`
          Expiration Date: Thu Feb 28 16:08:28 2013
cluster1::> security certificate truststore show -instance
                             Vserver: vs0
                    Certificate Name:  `_www.example.com_`
          FQDN or Custom Common Name:  `_www.example.com_`
        Serial Number of Certificate: 4F4E4D7B
                 Type of Certificate: server-ca
 Size of Requested Certificate(bits): 2048
              Certificate Start Date: Fri Apr 30 14:14:46 2010
         Certificate Expiration Date: Sat Apr 30 14:14:46 2011
              Public Key Certificate: -----BEGIN CERTIFICATE-----
                                      MIIDfTCCAmWgAwIBAwIBADANBgkqhkiG9w0BAQsFADBgMRQwEgYDVQQDEwtsYWIu
                                      YWJjLmNvbTELMAkGA1UEBhMCVVMxCTAHBgNVBAgTADEJMAcGA1UEBxMAMQkwBwYD
                                      VQQKEwAxCTAHBgNVBAsTADEPMA0GCSqGSIb3DQEJARYAMB4XDTEwMDQzMDE4MTQ0
                                      BgNVHQ8BAf8EBAMCAQYwHQYDVR0OBBYEFCVG7dYGe51akE14ecaCdL+LOAxUMA0G
                                      CSqGSIb3DQEBCwUAA4IBAQBJlE51pkDY3ZpsSrQeMOoWLteIR+1H0wKZOM1Bhy6Q
                                      +gsE3XEtnN07AE4npjIT0eVP0nI9QIJAbP0uPKaCGAVBSBMoM2mOwbfswI7aJoEh
                                      +XuEoNr0GOz+mltnfhgvl1fT6Ms+xzd3LGZYQTworus2
                                      -----END CERTIFICATE-----
        Country Name (2 letter code): US
  State or Province Name (full name): California
           Locality Name (e.g. city): Sunnyvale
    Organization Name (e.g. company): example
    Organization Unit (e.g. section): IT
        Email Address (Contact Name):  `_web@example.com_`
                            Protocol: SSL
                    Hashing Function: SHA256
 PDFs
PDFs
