lun portset show
Displays a list of portsets
This command displays the LIFs in a port set. By default, the command displays all LIFs in all port sets.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Selects the port sets that match this parameter value.
[-portset <text>]- Portset Name-
[-port-name <port_name>,…]- LIF Or TPG Name-
[-protocol {mixed|fcp|iscsi}]- Protocol-
[-port-count <integer>]- Number Of Ports-
[-igroups <igroup>,…]- Bound To Igroups-
cluster1::> lun portset show
Vserver Portset Protocol Port Names Igroups
vs1 ps0 mixed lif1, lif2 igroup1
ps1 iscsi lif3 igroup2
ps2 fcp lif4 -
3 entries were displayed.
The example above displays all port sets.
cluster1::> lun portset show -port-count 0 Vserver Portset Protocol Port Names Igroups --------- ------------ -------- ----------------------- ------------ vs1 p1 iscsi - -
The example above displays the port sets that contain zero LIFs.
cluster1::> lun portset show -protocol iscsi Vserver Portset Protocol Port Names Igroups --------- ------------ -------- ----------------------- ------------ vs1 p1 iscsi - - vs1 iscsips iscsi lif1 igroup1 2 entries were displayed.
The example above displays the port sets that have the iSCSI protocol.
cluster1::> lun portset show -port-name lif1 Vserver Portset Protocol Port Names Igroups --------- ------------ -------- ----------------------- ------------ vs1 iscsips iscsi lif1 igroup1
The example above displays the port sets that contain LIF lif1.
