lun portset show
Displays a list of portsets
This command displays the LIFs in a port set. By default, the command displays all LIFs in all port sets.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Selects the port sets that match this parameter value.
[-portset <text>] - Portset Name
[-port-name <port_name>,…​] - LIF Or TPG Name
[-protocol {mixed|fcp|iscsi}] - Protocol
[-port-count <integer>] - Number Of Ports
[-igroups <igroup>,…​] - Bound To Igroups
cluster1::> lun portset show
Vserver   Portset      Protocol Port Names              Igroups
vs1       ps0          mixed    lif1, lif2              igroup1
          ps1          iscsi    lif3                    igroup2
          ps2          fcp      lif4                    -
3 entries were displayed.
The example above displays all port sets.
cluster1::> lun portset show -port-count 0
vs1       p1           iscsi    -                       -
The example above displays the port sets that contain zero LIFs.
cluster1::> lun portset show -protocol iscsi
vs1       p1           iscsi    -                       -
vs1       iscsips      iscsi    lif1                    igroup1
2 entries were displayed.
The example above displays the port sets that have the iSCSI protocol.
cluster1::> lun portset show -port-name lif1
The example above displays the port sets that contain LIF lif1.
