storage shelf show
Display a list of storage shelves
The storage shelf show command displays information about all the storage shelves in the storage system. If no parameters are specified, the default command displays the following information about the storage shelves:
Shelf Name
Shelf ID
Serial Number
Model
Module Type
Status
To display detailed profile information about a single storage shelf, use the -shelf parameter.
[-fields <fieldname>,…] -
Displays the specified fields for all the storage shelves, in column style output.
[-bay ] -
Displays the following details about the disk bays in the storage shelf:
The unique positional identifier of the disk bay
Whether a disk drive is installed in the bay
Bay type
Operational status of the disk bay
[-connectivity ] -
Displays the following details about the connectivity from the node to the storage shelf:
Node name
Initiator side switch port
Target side switch port
World-wide port name
Target Port Group Number (TPGN)
[-cooling ] -
Displays the following details about the cooling elements and temperature sensors of the storage shelf:
Element ID of the cooling fan
The current speed of the cooling fan in revolutions per minute (rpm)
Operational status of the cooling fan
Sensor ID of the temperature sensor element
Temperature at the sensor in degrees Celsius
Whether the current temperature at the sensor is the ambient temperature
Low critical threshold value for the temperature sensor
Low warning threshold value for the temperature sensor
High critical threshold value for the temperature sensor
High warning threshold value for the temperature sensor
Operational status for the temperature sensor
[-errors ] -
Displays the following error status information about the storage shelves that have errors:
Error type
Error description
[-module ] -
Displays the following details about the I/O modules attached to the storage shelf:
Module ID
Module part number
Serial number of the Enclosure Services Controller Electronics element
Whether monitoring is enabled on this module
Whether this module is the SAS expander master module
Whether this module is the element reporting
Version of the firmware installed on the module
Latest firmware revision
Number of times, since the last boot, that this module has been swapped
Operational status of the module
[-port ] -
Displays the following details about the storage shelf ports:
Expander phy element identifier
SAS shelf port type
World-wide Port Name of the SAS port
Operational physical link rate of the SAS port in Gb/s
Negotiated physical link rate of the SAS port in Gb/s
Power status of the SAS port
Status of the SAS port
Fibre Channel shelf port ID
Fibre Channel shelf port type
Fibre Channel shelf port status
[-power ] -
Displays the following details about the power supplies, voltage sensors, and current sensors of the storage shelf:
Power Supply Unit (PSU) number
PSU type
PSU part number
PSU serial number
PSU power rating in watts
PSU crest factor
Power drawn from the PSU in watts
Whether the PSU can be reset via software control
Whether the auto power reset of the PSU is enabled
PSU firmware revision
Operational status of the PSU
Voltage sensor number
Voltage detected by the voltage sensor, in volts (V)
Operational status of the voltage sensor
Current sensor number
Current detected by the current sensor, in milliamps (mA)
Operational status of the current sensor
[-instance ]} -
Displays expanded information about all the storage shelves in the system.
[-node {<nodename>|local}]- Node-
Displays information only about the storage shelves that are attached to the node you specify.
[-shelf <text>]- Shelf Name-
Displays information only about the storage shelves that match the names you specify.
[-shelf-uid <text>]- Shelf UID-
Displays information only about the storage shelf that matches the shelf UID you specify. Example: `50:05:0c:c0:02:10:64:26 `
[-stack-id {<integer>|-}]- Stack ID-
Displays information only about the storage shelves that are attached to the stack that matches the stack ID you specify
[-shelf-id <text>]- Shelf ID-
Displays information only about the storage shelves that match the shelf ID you specify.
[-module-type {unknown|atfcx|esh4|iom3|iom6|iom6e|iom12|iom12e|iom12f|nsm100|psm3e|iom12b}]- Shelf Module Type-
Displays information only about the storage shelves that match the module-type you specify.
[-connection-type {unknown|fc|sas|nvme}]- Shelf Connection Type-
Displays information only about the storage shelves that match the connection type you specify. Example: FC or SAS.
[-is-local-attach {true|false}]- Is the Shelf Local to This Cluster?-
Displays information only about the storage shelves that are local (TRUE) or remote (FALSE) to this cluster.
[-vendor <text>]- Shelf Vendor-
Displays information only about the storage shelves that match the vendor you specify.
[-product-id <text>]- Shelf Product Identification-
Displays information only about the storage shelves that match the product ID you specify.
[-serial-number <text>]- Shelf Serial Number-
Displays information only about the storage shelf that matches the serial number you specify.
[-disk-count {<integer>|-}]- Disk Count-
Displays information only about the storage shelves that have the disk count you specify.
[-state {unknown|no-status|init-required|online|offline|missing}]- Shelf State-
Displays information only about the storage shelves that are in the state you specify.
[-op-status {unknown|normal|warning|error|critical|standby-power}]- Shelf Operational Status-
Displays information only about the storage shelves that are currently operating under the status condition you specify.
[-bay-id {<integer>|-}]- Bay ID-
Displays information only about the storage shelves that have bays that match the bay ID you specify.
[-bay-type {unknown|single-disk|multi-lun}]- Bay Type-
Displays information only about the storage shelves that have bays that match the type of bay you specify.
[-bay-has-disk {true|false}]- Bay Has Disk-
Displays information only about the storage shelves that have bays with disk drives inserted in them (true) or empty bays (false).
[-bay-op-status {unknown|normal|error}]- Bay Operational Status-
Displays information only about the storage shelves that have bays that match the operational state you specify.
[-controller {<nodename>|local}]- Controller Name-
Displays information only about the storage shelves that are connected to the node you specify.
[-controller-uuid <text>,…]- Controller UUID-
Displays information only about the storage shelves that are connected to the node UUID you specify.
[-initiator <text>,…]- Initiator-
Displays information only about the storage shelves that are visible to the initiator you specify.
[-initiator-wwpn <text>,…]- Initiator WWPN-
Displays information only about the storage shelves that are visible to the initiator WWPN you specify.
[-initiator-side-switch-port <text>,…]- Initiator Side Switch Port-
Displays information only about the storage shelves that are visible to an initiator connected to the switch port you specify.
[-target-side-switch-port <text>,…]- Target Side Switch Port-
Displays information only about the storage shelves visible on target ports identified by the switch port to which they are connected.
[-target-port <text>,…]- Target Port-
Displays information only about the storage shelves visible on the specified target ports identified by their World-Wide Port Name (WWPN).
[-tpgn {<integer>|-}]- Target Port Group Number-
Displays information only about the storage shelves that belong to the Target Port Group Name (TPGN) you specify.
[-port-speed {<integer>|-}]- Port Speed-
Displays information only about the storage shelves with ports that match the port speed you specify.
[-io-kbps {<integer>|-}]- Kbytes/sec on Storage Shelf-
Displays information only about the storage shelves visible to an initiator that has executed I/O at the throughput you specify.
[-iops {<integer>|-}]- Number IOPS per Second on Storage Shelf-
Displays information only about the storage shelves visible to an initiator that has executed the number of IOPs you specify.
[-current-sensor-id {<integer>|-}]- Current Sensor ID-
Displays information only about the storage shelves with current sensor that matches the current sensor ID you specify.
[-current-sensor-location <text>,…]- Current Sensor Location-
Displays information only about the storage shelves with current sensors installed at the location you specify.
[-current-sensor-reading {<integer>|-}]- Current Sensor Reading-
Displays information only about the storage shelves with current sensors that match the current reading you specify.
[-current-op-status {unknown|normal|over-current-critical|under-current-critical|not-supported|not-installed}]- Operational Status-
Displays information only about the storage shelves with current sensors that match the operational status you specify.
[-fan-id {<integer>|-}]- Fan ID-
Displays information only about the storage shelves with cooling fans that match the fan IDs you specify.
[-fan-location <text>,…]- Fan Location-
Displays information only about the storage shelves with cooling fans installed.
[-fan-rpm {<integer>|-}]- Fan Rotation Per Minute-
Displays information only about the storage shelves with cooling fans that match the rpm rate you specify.
[-fan-op-status {unknown|normal|off|error|not-supported|not-installed}]- Fan Operational Status-
Displays information only about the storage shelves with cooling fans that match the operational status you specify.
[-module-id <text>,…]- Module ID-
Displays information only about the storage shelves with an I/O module that matches the module ID you specify.
[-module-location <text>,…]- Module Location-
Displays information only about the storage shelves with I/O modules in the specified shelf module slots.
[-module-part-number <text>,…]- Module Part Number-
Displays information only about the storage shelves with I/O modules that match the module part numbers you specify.
[-is-sas-master-module {true|false}]- Is SAS Expander Master Module?-
Displays information only about the storage shelves with a SAS master I/O module (true) or an I/O module that is not a SAS master (false). This parameter applies only to SAS shelves.
[-is-monitor-active {true|false}]- Is Monitor Active?-
Displays information only about the storage shelves whose monitoring is enabled (true) or disabled (false).
[-enclosure-type <text>,…]- Module Enclosure Type-
Displays information only about the storage shelves that match the enclosure types you specify.
[-es-serial-number <text>,…]- ES Electronics Element Serial Number-
Displays information only about the storage shelves with I/O modules that match the electronics serial numbers you specify.
[-module-fru-id <text>,…]- Field Replaceable Unit ID-
Displays information only about the storage shelves with I/O modules that match the field replaceable unit (FRU) IDs you specify.
[-module-is-reporting-element {true|false}]- Is Reporting Element?-
Displays information only about the storage shelves with element reporting I/O modules (true) or not (false).
[-module-fw-revision <text>,…]- Firmware Revision-
Displays information only about the storage shelves with I/O modules that match the firmware revision you specify.
[-module-latest-fw-revision <text>,…]- Latest Firmware Revision-
Displays information only about the storage shelves with I/O modules that match the latest firmware revision you specify.
[-module-fw-progress {not-available|ready|in-progress|failed}]- Module Firmware Progress-
Displays information only about the storage shelves with I/O modules that match the specified firmware update progress.
[-module-swap-count {<integer>|-}]- Module Swap Count-
Displays information only about the storage shelves whose I/O modules have been swapped the specified number of times.
[-module-op-status {unknown|normal|warning|error}]- Module Operational Status-
Displays information only about the storage shelves with I/O modules that match the operational status you specify.
[-sas-port-id <text>,…]- Port ID-
Displays information only about the storage shelves with SAS Ports that match the port IDs you specify.
[-sas-port-type {unknown|circle|square|sil|disk|in|out|unused|host|dcm|aux1|aux2|hi_ho|a_to_b|b_to_a}]- Port Type-
Displays information only about the storage shelves with SAS Ports that match the SAS port type you specify.
[-sas-port-wwpn <text>,…]- Port World Wide Port Name-
Displays information only about the storage shelves with SAS Ports that match the World-Wide Port Names you specify.
[-sas-port-speed <text>,…]- Port Speed-
Displays information only about the storage shelves with SAS Ports that match the port speed you specify.
[-sas-negotiated-port-speed <text>,…]- Negotiated Port Speed-
Displays information only about the storage shelves with SAS Ports that match the negotiated port speed you specify.
[-sas-port-power-status <text>,…]- Port Power Status-
Displays information only about the storage shelves with SAS Ports that match the power status you specify.
[-sas-port-op-status {error|normal|off|unknown|byp-bad-term|bad-zone-recovery|byp_clk_thr|byp_comma_los|byp_crc_brst_thr|byp_data_timeout|byp_drv_fault|byp_drv_pcycle|byp_drv_pwr|byp_drv_self|byp_gen|byp_init|byp_lip_brst_thr|byp_lip_f8|byp_lip_rate_thr|byp_lipf7|byp_ltbi|byp_man|byp_no_drive|byp_osc|byp_other_thr|byp_rec_los|byp_rport|byp_stall_thr|byp_wrd_brst_thr|byp_wrd_rate_thr|byp_xmit_fault|diag_transmit|inserted|loopback|status_unknown|warn_high_clk_delta|warn_high_crc_rate|warn_high_lip|warn_high_wrd_rate|term|phy_dis_clk_fault|phy_dis_crc_err|phy_dis_crc_err_burst|phy_dis_disparity|phy_dis_disparity_burst|phy_dis_emulate_reserve|phy_dis_inval_dword|phy_dis_inval_dword_burst|phy_dis_loss_dword|phy_dis_loss_dword_burst|phy_dis_man_smp|phy_dis_manual|phy_dis_mirrored|empty|phy_dis_phy_change|phy_dis_phy_change_burst|phy_dis_phy_reset|phy_dis_phy_reset_burst|phy_dis_phy_unused|phy_ena|phy_ena_not_attach|phy_ena_unknown|phy_unknown|phy_dis_illegal}]- Port Operational Status-
Displays information only about the storage shelves with SAS Ports that match the operational status you specify.
[-sas-port-module-id {A|B}]- Port Module ID-
Displays information only about the storage shelves with SAS Ports that match the module ID you specify.
[-fc-port-id <text>,…]- Fibre Channel Port ID-
Displays information only about the storage shelves with FC Ports that match the port IDs you specify.
[-fc-port-mode {unknown|circle|square|sil|disk|in|out|unused|host|dcm|aux1|aux2|hi_ho|a_to_b|b_to_a}]- Fibre Channel Port Mode-
Displays information only about the storage shelves with FC Ports that match the port modes you specify.
[-fc-port-op-status {error|normal|off|unknown|byp-bad-term|bad-zone-recovery|byp_clk_thr|byp_comma_los|byp_crc_brst_thr|byp_data_timeout|byp_drv_fault|byp_drv_pcycle|byp_drv_pwr|byp_drv_self|byp_gen|byp_init|byp_lip_brst_thr|byp_lip_f8|byp_lip_rate_thr|byp_lipf7|byp_ltbi|byp_man|byp_no_drive|byp_osc|byp_other_thr|byp_rec_los|byp_rport|byp_stall_thr|byp_wrd_brst_thr|byp_wrd_rate_thr|byp_xmit_fault|diag_transmit|inserted|loopback|status_unknown|warn_high_clk_delta|warn_high_crc_rate|warn_high_lip|warn_high_wrd_rate|term|phy_dis_clk_fault|phy_dis_crc_err|phy_dis_crc_err_burst|phy_dis_disparity|phy_dis_disparity_burst|phy_dis_emulate_reserve|phy_dis_inval_dword|phy_dis_inval_dword_burst|phy_dis_loss_dword|phy_dis_loss_dword_burst|phy_dis_man_smp|phy_dis_manual|phy_dis_mirrored|empty|phy_dis_phy_change|phy_dis_phy_change_burst|phy_dis_phy_reset|phy_dis_phy_reset_burst|phy_dis_phy_unused|phy_ena|phy_ena_not_attach|phy_ena_unknown|phy_unknown|phy_dis_illegal}]- Fibre Channel Port Operational Status-
Displays information only about the storage shelves with FC Ports that match the operational status you specify.
[-psu-id {<integer>|-}]- Power Supply Unit ID-
Displays information only about the storage shelves with power supply units (PSU) that match the unit IDs you specify.
[-psu-location <text>,…]- Power Supply Unit Location-
Displays information only about the storage shelves with PSUs that are located at the specified location inside the shelf.
[-psu-type <text>,…]- Power Supply Unit Type-
Displays information only about the storage shelves with PSUs that match the PSU types you specify.
[-psu-part-number <text>,…]- Power Supply Unit Part Number-
Displays information only about the storage shelves with PSUs that match the PSU part number you specify.
[-psu-serial-number <text>,…]- Power Supply Unit Serial Number-
Displays information only about the storage shelves with PSUs that match the PSU serial numbers you specify.
[-psu-reset-capable {true|false}]- Power Supply Unit Reset Capability-
Displays information only about the storage shelves with reset capable PSUs (true) or reset incapable PSUs (false).
[-psu-is-enabled {true|false}]- Power Supply Unit Enable/Disable Status-
Displays information only about the storage shelves with PSUs that are enabled (true) or disabled (false).
[-psu-fw-version <text>,…]- Power Supply Unit Firmware Version-
Displays information only about the storage shelves with PSUs that have the firmware version you specify.
[-psu-op-status {unknown|normal|error|dc-over-voltage|dc-under-voltage|dc-over-current|over-temperature-error|failed|off|not-supported|not-installed}]- Operational Status-
Displays information only about the storage shelves with PSUs that match the operational status you specify.
[-psu-power-rating {<integer>|-}]- Power Supply Power Ratings In Watts-
Displays information only about the storage shelves with PSUs that match the power rating you specify.
[-psu-crest-factor {<integer>|-}]- Power Supply Crest Factor-
Displays information only about the storage shelves with PSUs that match the crest factor value you specify.
[-psu-power-drawn {<integer>|-}]- Power Drawn From PSU In Watts-
Displays information only about the storage shelves with PSUs that match the drawn power you specify.
[-temp-sensor-id {<integer>|-}]- Sensor Name-
Displays information only about the storage shelves with temperature sensors that match the sensor IDs you specify.
[-temp-sensor-location <text>,…]- Sensor Location-
Displays information only about the storage shelves with temperature sensors that match the specified sensor locations inside the shelf.
[-temp-sensor-reading {<integer>|-}]- Temperature Reading-
Displays information only about the storage shelves with temperature sensors that match the temperature reading you specify.
[-temp-is-ambient {true|false}]- Temperature Reading at Ambient Value-
Displays information only about the storage shelves with temperature sensors whose current temperature reading is ambient (true) or not (false).
[-temp-high-critical-threshold {<integer>|-}]- High Critical Threshold-
Displays information only about the storage shelves with temperature sensors that match the high critical threshold you specify.
[-temp-high-warning-threshold {<integer>|-}]- High Warning Threshold-
Displays information only about the storage shelves with temperature sensors that match the high warning threshold you specify.
[-temp-low-warning-threshold {<integer>|-}]- Low Warning Threshold-
Displays information only about the storage shelves with temperature sensors that match the low warning threshold you specify.
[-temp-low-critical-threshold {<integer>|-}]- Low Critical Threshold-
Displays information only about the storage shelves with temperature sensors that match the low critical threshold you specify.
[-temp-op-status {unknown|normal|under-temperature|over-temperature|error|not-supported|not-installed}]- Operational Status-
Displays information only about the storage shelves with temperature sensors that match the operational status you specify.
[-voltage-sensor-id {<integer>|-}]- Voltage Sensor ID-
Displays information only about the storage shelves with voltage sens- ors that match the sensor IDs you specify.
[-voltage-sensor-location <text>,…]- Voltage Sensor Location-
Displays information only about the storage shelves with voltage sens- ors that match the specified sensor locations inside the shelf.
[-voltage-sensor-reading <text>,…]- Voltage Current Reading-
Displays information only about the storage shelves with voltage sens- ors that match the voltage reading you specify.
[-voltage-op-status {unknown|normal|over-voltage-critical|under-voltage-critical|not-supported|not-installed|not-recoverable}]- Operational Status-
Displays information only about the storage shelves with voltage sens- ors that match the operational status you specify.
[-error-type {unknown|acpp|bay|bootdevice|coinbattery|configuration|current|dimm|disk|internal|fan|module|port|power|temperature|voltage}]- Error Type-
Displays information only about the storage shelves with errors that match the error type you specify.
[-error-severity {unknown|notice|warning|error|critical}]- Error Severity-
Displays information only about the storage shelves with errors that match the error severity you specify.
[-nsm-port-module-id {A|B}]- Port Module ID-
Displays information only about the storage shelves with PCIe Ports from the specified module.
[-nsm-port-id <integer>,…]- Port ID-
Displays information only about the storage shelves with PCIe Ports that match the specified ID.
[-nsm-port-type {cpu|disk|cx5|ethernet}]- Port Type-
Displays information only about the storage shelves with PCIe Ports that match the specified type.
[-nsm-port-state {ok|off-link-disabled|off-dll-link|link-down|no-drive}]- Port State-
Displays information only about the storage shelves with PCIe Ports that match the specified state.
[-nsm-port-bay <integer>,…]- Port Bay-
Displays information only about the storage shelves with PCIe Ports that match the specified bay.
[-nsm-port-disk-id <integer>,…]- Port Disk ID-
Displays information only about the storage shelves with PCIe Ports that match the specified disk ID.
[-nsm-port-is-installed {true|false}]- Port Is Disk Installed-
Displays information only about the storage shelves with PCIe Ports that have a disk installed.
[-nsm-port-is-error {true|false}]- Port Has Error-
Displays information only about the storage shelves with PCIe Ports that have errors.
[-nsm-port-speed {2.5|5.0|8.0}]- Port Speed-
Displays information only about the storage shelves with PCIe Ports that match the specified speed.
[-nsm-port-speed-max {2.5|5.0|8.0}]- Max Port Speed-
Displays information only about the storage shelves with PCIe Ports that match the specified maximum speed.
[-nsm-port-lane-width <integer>,…]- Port Lane Width-
Displays information only about the storage shelves with PCIe Ports that match the specified lane width.
[-nsm-port-lane-width-max <integer>,…]- Max Port Lane Width-
Displays information only about the storage shelves with PCIe Ports that match the specified maximum lane width.
[-dimm-module-id {A|B}]- DIMM Module ID-
Displays information only about the storage shelves with DIMMs from the specified module.
[-dimm-id <integer>,…]- DIMM ID-
Displays information only about the storage shelves with DIMMs that match the specified ID.
[-dimm-serial-number <text>,…]- DIMM Serial Number-
Displays information only about the storage shelves with DIMMs that match the specified serial number.
[-dimm-part-number <text>,…]- DIMM Part Number-
Displays information only about the storage shelves with DIMMs that match the specified part number.
[-dimm-vendor <text>,…]- DIMM Vendor-
Displays information only about the storage shelves with DIMMs that match the specified vendor.
[-dimm-type <text>,…]- DIMM Type-
Displays information only about the storage shelves with DIMMs that match the specified type.
[-dimm-size <text>,…]- DIMM Size-
Displays information only about the storage shelves with DIMMs that match the specified size.
[-dimm-speed <text>,…]- DIMM Speed-
Displays information only about the storage shelves with DIMMs that match the specified speed.
[-dimm-location <text>,…]- DIMM Location-
Displays information only about the storage shelves with DIMMs that match the specified location.
[-dimm-op-status {unknown|normal|error|not-supported|not-installed}]- DIMM Operational Status-
Displays information only about the storage shelves with DIMMs that match the specified operational status.
[-boot-device-module-id {A|B}]- Boot Device Module ID-
Displays information only about the storage shelves with boot devices from the specified module.
[-boot-device-id <integer>,…]- Boot Device ID-
Displays information only about the storage shelves with boot devices that match the specified ID.
[-boot-device-serial-number <text>,…]- Boot Device Serial Number-
Displays information only about the storage shelves with boot devices that match the specified serial number.
[-boot-device-part-number <text>,…]- Boot Device Part Number-
Displays information only about the storage shelves with boot devices that match the specified part number.
[-boot-device-vendor <text>,…]- Boot Device Vendor-
Displays information only about the storage shelves with boot devices that match the specified vendor.
[-boot-device-type <text>,…]- Boot Device Type-
Displays information only about the storage shelves with boot devices that match the specified type.
[-boot-device-size <text>,…]- Boot Device Size-
Displays information only about the storage shelves with boot devices that match the specified size.
[-boot-device-op-status {unknown|normal|error|not-supported|not-installed}]- Boot Device Operational Status-
Displays information only about the storage shelves with boot devices that match the specified operational status.
[-coin-battery-module-id {A|B}]- Coin Battery Module ID-
Displays information only about the storage shelves with coin batteries from the specified module.
[-coin-battery-id <integer>,…]- Coin Battery ID-
Displays information only about the storage shelves with coin batteries that match the specified ID.
[-coin-battery-voltage <integer>,…]- Coin Battery Voltage (mV)-
Displays information only about the storage shelves with coin batteries that match the specified voltage.
[-coin-battery-op-status {unknown|normal|error|low|high|not-supported|not-installed}]- Coin Battery Operational Status-
Displays information only about the storage shelves with coin batteries that match the specified operational status.
The following example displays information about all storage shelves:
cluster1::> storage shelf show
Module Operational
Shelf Name Shelf ID Serial Number Model Type Status
1.1 1 6000832415 DS2246 IOM6 Critical
1.2 2 6000647652 DS2246 IOM6 Normal
1.3 3 6000003844 DS2246 IOM6 Normal
1.4 4 SHJ000000013A9E DS4246 IOM6 Normal
1.5 5 SHJ000000013A84 DS4246 IOM6 Normal
1.6 6 6000005555 DS2246 IOM6 Normal
6 entries were displayed.
cluster1::>
The following example displays expanded information about a storage shelf named 1.2:
cluster1::> storage shelf show -shelf 1.2 -instance
Shelf Name: 1.2
Stack ID: 1
Shelf ID: 2
Shelf UID: 50:0a:09:80:01:b9:75:41
Serial Number: 6000647652
Module Type: IOM6
Model: DS2246
Shelf Vendor: NETAPP
Disk Count: 12
Connection Type: SAS
Shelf State: Online
Status: Normal
Modules: Module is
Monitor Is Reporting FW Update Latest Swap Operational Module
ID Part No. ES Serial No. is Active Master Element Progress FW Rev. FW Rev. Count Status Location
a 111-00190+A0 8006437891 true false false not-available 0191 - 0 normal rear of the shelf at the top left
b 111-00190+A0 8006435180 true true true not-available 0191 - 0 normal rear of the shelf at the top right
Paths:
Speed
Controller Initiator Initiator Side Switch Port Target Side Switch Port Target Port TPGN Gb/s I/O KB/s IOPS
stsw-8020-01 0a - - - - - - -
stsw-8020-01 2b - - - - - - -
stsw-8020-02 0a - - - - - - -
stsw-8020-02 2b - - - - - - -
Power Supply Units:
Crest Power Reset PSU Operational
ID Type Part# Serial# Power Rating Factor Drawn Capable Enabled Firmware Status PSU Location
1 9C 114-00065+A1 XXT131052637 - - - false true 020F normal rear of the shelf at the bottom left
2 9C 114-00065+A1 XXT131052551 - - - false true 020F normal rear of the shelf at the bottom right
Voltage Sensors:
Voltage Operational
ID (V) Status Sensor Location
1 5.70 normal rear of the shelf on the lower left power supply
2 12.300 normal rear of the shelf on the lower left power supply
3 5.70 normal rear of the shelf on the lower right power supply
4 12.180 normal rear of the shelf on the lower right power supply
Current Sensors:
Current Operational
ID (mA) Status Sensor Location
1 0 normal rear of the shelf on the lower left power supply
2 0 normal rear of the shelf on the lower left power supply
3 0 normal rear of the shelf on the lower right power supply
4 0 normal rear of the shelf on the lower right power supply
Fans:
Speed Operational
ID (RPM) Status Fan Location
1 3000 normal rear of the shelf on the lower left power supply
2 2970 normal rear of the shelf on the lower left power supply
3 3000 normal rear of the shelf on the lower right power supply
4 2970 normal rear of the shelf on the lower right power supply
Temperature:
-- Thresholds °C --
Temp Is Low Low High High Operational
ID °C Ambient Crit Warn Crit Warn Status Sensor Location
1 23 true 0 5 42 40 normal front of the shelf on the left, on the OPS panel
2 26 false 5 10 55 50 normal inside of the shelf on the midplane
3 24 false 5 10 55 50 normal rear of the shelf on the lower left power supply
4 39 false 5 10 70 65 normal rear of the shelf on the lower left power supply
5 25 false 5 10 55 50 normal rear of the shelf on the lower right power supply
6 36 false 5 10 70 65 normal rear of the shelf on the lower right power supply
7 25 false 5 10 60 55 normal rear of the shelf at the top left, on shelf module A
8 26 false 5 10 60 55 normal rear of the shelf at the top right, on shelf module B
SAS Ports:
-- Port Speeds Gb/s -- Power Port
Phy # IOM Port Type WWPN Operational Negotiated Status Status
0 A Square 500a098004b063b0 6.0 - - Enabled
1 A Square 500a098004b063b0 6.0 - - Enabled
2 A Square 500a098004b063b0 6.0 - - Enabled
3 A Square 500a098004b063b0 6.0 - - Enabled
4 A Circle 500a09800569f03f 6.0 - - Enabled
5 A Circle 500a09800569f03f 6.0 - - Enabled
6 A Circle 500a09800569f03f 6.0 - - Enabled
7 A Circle 500a09800569f03f 6.0 - - Enabled
8 A Disk 500605ba00c1cb8d 6.0 6.0 on Enabled
9 A Disk 500605ba00c1ea8d 6.0 6.0 on Enabled
10 A Disk 500605ba00c1d111 6.0 6.0 on Enabled
11 A Disk 500605ba00c1bc49 6.0 6.0 on Enabled
12 A Disk 500605ba00c1cdfd 6.0 6.0 on Enabled
13 A Disk 500605ba00c1c531 6.0 6.0 on Enabled
14 A Disk 500605ba00c1eb05 6.0 6.0 on Enabled
15 A Disk 500605ba00c1ec29 6.0 6.0 on Enabled
16 A Disk 500605ba00c1bc29 6.0 6.0 on Enabled
17 A Disk 500605ba00c1c471 6.0 6.0 on Enabled
18 A Disk 500605ba00c039a9 6.0 6.0 on Enabled
19 A Disk 500605ba00c1c4dd 6.0 6.0 on Enabled
20 A Disk - - - - Empty
21 A Disk - - - - Empty
22 A Disk - - - - Empty
23 A Disk - - - - Empty
24 A Disk - - - - Empty
25 A Disk - - - - Empty
26 A Disk - - - - Empty
27 A Disk - - - - Empty
28 A Disk - - - - Empty
29 A Disk - - - - Empty
30 A Disk - - - - Empty
31 A Disk - - - - Empty
32 A SIL - - - - Disabled
33 A SIL - - - - Disabled
34 A SIL - - - - Disabled
35 A SIL - - - - Disabled
0 B Square 500a098004af9e30 6.0 - - Enabled
1 B Square 500a098004af9e30 6.0 - - Enabled
2 B Square 500a098004af9e30 6.0 - - Enabled
3 B Square 500a098004af9e30 6.0 - - Enabled
4 B Circle 500a098005688dbf 6.0 - - Enabled
5 B Circle 500a098005688dbf 6.0 - - Enabled
6 B Circle 500a098005688dbf 6.0 - - Enabled
7 B Circle 500a098005688dbf 6.0 - - Enabled
8 B Disk 500605ba00c1cb8e 6.0 6.0 on Enabled
9 B Disk 500605ba00c1ea8e 6.0 6.0 on Enabled
10 B Disk 500605ba00c1d112 6.0 6.0 on Enabled
11 B Disk 500605ba00c1bc4a 6.0 6.0 on Enabled
12 B Disk 500605ba00c1cdfe 6.0 6.0 on Enabled
13 B Disk 500605ba00c1c532 6.0 6.0 on Enabled
14 B Disk 500605ba00c1eb06 6.0 6.0 on Enabled
15 B Disk 500605ba00c1ec2a 6.0 6.0 on Enabled
16 B Disk 500605ba00c1bc2a 6.0 6.0 on Enabled
17 B Disk 500605ba00c1c472 6.0 6.0 on Enabled
18 B Disk 500605ba00c039aa 6.0 6.0 on Enabled
19 B Disk 500605ba00c1c4de 6.0 6.0 on Enabled
20 B Disk - - - - Empty
21 B Disk - - - - Empty
22 B Disk - - - - Empty
23 B Disk - - - - Empty
24 B Disk - - - - Empty
25 B Disk - - - - Empty
26 B Disk - - - - Empty
27 B Disk - - - - Empty
28 B Disk - - - - Empty
29 B Disk - - - - Empty
30 B Disk - - - - Empty
31 B Disk - - - - Empty
32 B SIL - - - - Disabled
33 B SIL - - - - Disabled
34 B SIL - - - - Disabled
35 B SIL - - - - Disabled
FC Ports:
Port
ID Port Type Status
Bays:
Has Operational
ID Disk Bay Type Status
0 true single-disk normal
1 true single-disk normal
2 true single-disk normal
3 true single-disk normal
4 true single-disk normal
5 true single-disk normal
6 true single-disk normal
7 true single-disk normal
8 true single-disk normal
9 true single-disk normal
10 true single-disk normal
11 true single-disk normal
12 false single-disk normal
13 false single-disk normal
14 false single-disk normal
15 false single-disk normal
16 false single-disk normal
17 false single-disk normal
18 false single-disk normal
19 false single-disk normal
20 false single-disk normal
21 false single-disk normal
22 false single-disk normal
23 false single-disk normal
cluster1::>
The following example displays information about the power supplies, voltage sensors and current sensors of the storage shelf 1.1:
cluster1::> storage shelf show -shelf 1.1 -power
Shelf Name: 1.1
Stack ID: 1
Shelf ID: 1
Shelf UID: 50:0a:09:80:01:cb:d6:84
Serial Number: 6000832415
Module Type: IOM6
Model: DS2246
Disk Count: 12
Shelf State: Online
Status: Normal
Power Supply Units:
1 9C 114-00065+A1 XXT132835072 - - - false true 020F normal
2 9C 114-00065+A1 XXT132835073 - - - false true 020F normal
Voltage Sensors:
Voltage Operational
ID (V) Status
1 5.70 normal
2 12.180 normal
3 5.70 normal
4 12.300 normal
Current Sensors:
Current Operational
ID (mA) Status
1 0 normal
2 0 normal
3 3900 normal
4 0 normal
Errors:
Critical condition is detected in storage shelf power supply unit "1". The unit might fail.
Critical over temperature failure for temperature sensor "1". Current temperature: "75" C ("167" F).
cluster1::>
The following example displays information about the cooling elements and temperature sensors inside the storage shelf 1.2:
cluster1::> storage shelf show -shelf 1.2 -cooling
Shelf Name: 1.2
Stack ID: 1
Shelf ID: 2
Module Type: IOM6
Model: DS2246
Disk Count: 12
Shelf State: Online
Status: Normal
Fans:
Speed Operational
ID (RPM) Status
1 3000 normal
2 3000 normal
3 3000 normal
4 2970 normal
Temperature:
-- Thresholds °C --
8 27 false 5 10 60 55 normal
Errors:
cluster1::>
The following example displays information about the connectivity from the node to the storage shelf 1.2:
cluster1::> storage shelf show -shelf 1.2 -connectivity
Shelf Name: 1.2
Stack ID: 1
Shelf ID: 2
Module Type: IOM6
Model: DS2246
Disk Count: 12
Shelf State: Online
Status: Normal
Paths:
Errors:
cluster1::>
The following example displays information about the disk bays of the storage shelf 1.2:
cluster1::> storage shelf show -shelf 1.2 -bay
Shelf Name: 1.2
Stack ID: 1
Shelf ID: 2
Module Type: IOM6
Model: DS2246
Disk Count: 12
Shelf State: Online
Status: Normal
Bays:
Has Operational
Errors:
cluster1::>
The following example displays information about the ports of the storage shelf 1.2:
cluster1::> storage shelf show -shelf 1.2 -port
Shelf Name: 1.2
Stack ID: 1
Shelf ID: 2
Module Type: IOM6
Model: DS2246
Disk Count: 12
Shelf State: Online
Status: Normal
SAS Ports:
FC Ports:
Port
ID Port Type Status
Errors:
cluster1::>
The following example displays error information about the storage shelves that have errors:
cluster1::> storage shelf show -errors
Shelf Name: 1.1
Error Type Description
Power Critical condition is detected in storage shelf power supply unit "1". The unit might fail.
Temperature Critical over temperature failure for temperature sensor "1". Current temperature: "75" C ("167" F).
