system node nfs usage show
PDF of this doc site
Creating your file...
Show NFS usage in the local node
The system node nfs usage show
command displays the NFS usage information in the local node. The display output shows the number of RPC calls received per protocol on the local node. Usage is collected whenever there is any NFS traffic. These values are not persistent and will reset when the node reboots. This command is used in conjunction with the system node nfs usage reset
command in the NFS licensing callback.
The following example displays the NFS usage information that does not have any NFS usage.
::*> system node nfs usage show Node: raghasri-vsim5 v3: 0 v4: 0
The following example displays the NFS usage information with v3 usage.
::*> system node nfs usage show Node: raghasri-vsim5 v3: 5 v4: 0
The following example displays the NFS usage information with v4 usage.
::*> system node nfs usage show Node: raghasri-vsim5 v3: 0 v4: 14
