snaplock log show
Display audit log configuration.
The snaplock log show command displays the following information about the SnapLock log infrastructure:
Vserver name
Volume name
Maximum log size
Default retention period
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name
If this parameter is specified, the command displays the log information for Vserveers that match the specified value.
- [-volume <volume name>]- Log Volume Name
If this parameter is specified, the command displays the log configuration for volumes that match the specified value.
- [-max-log-size {<integer>[KB|MB|GB|TB|PB]}]- Maximum Size of Log File
If this parameter is specified, the command displays the log configuration with a matching -max-log-sizevalue.
- [-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Default Log Record Retention Period
If this parameter is specified, the command displays the log configuration with a matching -default-retention-periodvalue.
cluster1::> snaplock log show -vserver vs1
Vserver Name                        : vs1
      Log Volume Name                     : 15MB
      Maximum Size of Log File            : 15MB
      Default Log Record Retention Period : 6 months
        Vserver           Volume              Maximum Size        Retention Period
        vs1               vol1                15MB                6 months
 PDFs
PDFs
