event mailhistory show
(DEPRECATED)-Display a list of e-mail history records
This command has been deprecated. It may be removed from a future release of Data ONTAP. Instead, use the "event notification history" command set. |
The event mailhistory show command displays a list of the event notifications that have been e-mailed. The command output depends on the parameters you specify with the command. By default, the command displays basic information about all notification e-mails that were sent.
To display detailed information about a specific mail-history record, run the command with the -seqnum parameter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the mail-history records that match this parameter value.
[-seqnum <Sequence Number>]- Sequence Number-
[-message-name <Message Name>]- Message Name-
[-address <mail address>,…]- Mail Address-
[-time <MM/DD/YYYY HH:MM:SS>]- Transmission Time-
[-message <text>]- Alert Message-
Selects the mail-history records that match this parameter value (text pattern).
[-previous-time <MM/DD/YYYY HH:MM:SS>]- Previous Transmission Time-
[-num-drops-since-previous <integer>]- Number of Drops Since Previous Transmission-
Selects the mail-history records that match this parameter value (number of event drops since last transmission).
The following example displays detailed information about the mail-history record with the sequence number 20520:
cluster1::> event mailhistory show -seqnum 20520
Sequence Number: 20520
Message Name: wafl.vol.full
Address: admin@example.com
Time: 10/1/2008 14:06:24
Node: node3
Previous Time: 5/31/2007 00:33:22
# Drops Since Prev: 0
Mail Message: wafl.vol.full: file system on volume
vol0@vserver:28558fe3-2462-11da-85ab
-000423bacd20 is full
