      vserver remove-protocols
Remove protocols from the Vserver
The vserver remove-protocols command removes the specified protocols from the specified Vserver. When you remove the protocols from a Vserver, the data access with respect to the removed protocols is disrupted.
- -vserver <vserver>- Vserver
Specifies the Vserver that is to be modified.
- -protocols {nfs|cifs|fcp|iscsi|ndmp|nvme}- Protocols
This parameter specifies the list of protocols to be removed. on the Vserver. Possible values include nfs,cifs,fcp,iscsi,ndmpandnvme.
The following example shows removing protocol 'cifs' from a Vserver named vs0.example.com.
cluster1::> vserver remove-protocols -vserver vs0.example.com -protocols cifs
 PDFs
PDFs
