security session limit location delete
Delete per-location session limit
This command allows deletion of a per-location management session limit.
-interface {cli|ontapi|rest} - Interface
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-location <text> - Location
The specified location to which this limit applies. The limit with the location name -default- (in the Default IPspace) is the limit used for any location (in any IPspace) without a specific configured limit.
[-ipspace <IPspace>] - IPspace of Location
This identifies the IPspace of the client location. If not specified, changes are made in the Default IPspace.
The following example illustrates deleting limits for management sessions from a specific set of locations.
cluster1::*> security session limit location delete -interface * -location 10.98.*
3 entries were deleted.
