ONTAP commands
system node upgrade-revert upgrade
Run the upgrade at a specific phase.
The system node upgrade-revert upgrade command manually executes an upgrade. Use this command to execute an upgrade after issues that caused an upgrade failure are resolved. If the upgrade is successful, no messages display.
Before the command executes upgrades, it checks the configuration of the nodes in the cluster. If no upgrades are needed, the command displays a message and does not execute any upgrades.
-node {<nodename>|local} - Node (privilege: advanced)
Specifies the node that is to be upgraded. The value local specifies the current node.
This example shows command output of a node named node0 if node configuration is current.
cluster1::*> system node upgrade-revert upgrade -node node0
The node configuration is up-to-date. No upgrade is needed.
