storage pool delete
Delete an existing storage pool
The storage pool delete
command deletes an existing SSD storage pool. At the end of the operation, the SSDs are converted back to spare disks.
-storage-pool <storage pool name>
- Storage Pool Name-
This parameter specifies the storage pool that you want to delete. You can delete the storage pool only if all of the allocation units in the storage pool are available.
Verify that storage pool SP3
is ready for deletion by confirming it has four available allocation units and then delete it.
cluster1::> storage pool show-available-capacity -storage-pool SP3 Storage SyncMirror Allocation Unit Total Node Storage Pool Type Pool Unit size Count Usable Size ---------- --------------- ------- ---------- ---------- ----- ----------- node-a SP3 SSD Pool0 372.5GB 2 744.9GB node-b SP3 SSD Pool0 372.5GB 2 744.9GB 2 entries were displayed. cluster1::> storage pool delete -storage-pool SP3 Warning: Are you sure you want to delete storage pool "SP3"? {y|n}: y [Job 313] Job succeeded: storage pool delete job for "SP3" completed successfully
