vserver vscan on-access-policy paths-to-exclude add
Add to the list of paths to exclude
The vserver vscan on-access-policy paths-to-exclude add
command adds a path or a list of paths that must be excluded from scanning to the specified policy name.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver containing the specified on-access policy to which you want to add a path or a list of paths that must be excluded from scanning.
-policy-name <Policy name>
- Policy-
This parameter specifies the name of the on-access policy to which you want to add a path or a list of paths that must be excluded from scanning.
-paths-to-exclude <File path>,…
- Paths Not to Scan-
This parameter specifies the path or list of paths that must be excluded from scanning.
The following example adds a list of paths that must be excluded from scanning to the specified on-access policy:
cluster1::> vserver vscan on-access-policy paths-to-exclude add -vserver vs1 -policy-name policy1 -paths-to-exclude \test\test2,\test\test3 cluster1::> vserver vscan on-access-policy paths-to-exclude show -vserver vs1 -policy-name policy1 Vserver: vs1 Policy: policy1 File-Paths Not to Scan: \test\test1, \test\test2, \test\test3
