system node virtual-machine instance show-system-disks
Display information about virtual machine system disks
The system node virtual-machine instance show-system-disks command displays information about the system disks (non-data disks) attached to the virtual machine. Data disk information is available using the command storage disk show-virtual-machine-disk-info .
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
Selects disk information for nodes that match this parameter.
[-vmdisk-purpose <text>]- Purpose of the System Disk-
Selects disk information for disks that match this parameter. Values include:
Boot,NVRAM, andCore. [-vmdisk-type <text>]- Type of the System Disk-
Selects disk information for disks that match this parameter. Possible values are:
VMDISK,SSD. [-vmdisk-id <text>]- System Disk ID-
Selects disk information for disks that match this parameter. The virtual machine ID of the system disk.
[-vmdisk-capacity <text>]- Size of the System Disk-
Selects disk information for disks that match this parameter. The size of the system disk.
[-vmdisk-file-name <text>]- File Name of the System Disk Used By the Hypervisor-
Selects disk information for disks that match this parameter. The virtual machine file name of the disk. Each system disk is mapped to a unique VM disk file..
The following example shows typical output from the command.
cluster1::> system node virtual-machine instance show-system-disks
Disk Disk Disk Disk
Node Purpose Type ID Capacity VM Disk File Name
node1
boot SSD 0 10GB node1-vm-disk-boot
nvram SSD 1 500GB node1-vm-disk-nvram
core VMDISK 2 216GB node1-vm-disk-core
