security key-manager key show
(DEPRECATED)-Display encryption key IDs stored in onboard key manager
|  | This command is deprecated and might be removed in a future release. Use security key-manager key query instead. |
This command displays the key IDs of the authentication keys (NSE-AK) and SVM keys (SVM-KEK) that are available in onboard key management. This command is not supported for an external key management configuration.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-detail ]
If this parameter is specified, the command displays additional details about the key IDs.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
If this parameter is specified, the command displays information only about key IDs that are located on the specified storage system.
- [-key-store <Key Store>]- Key Store
If this parameter is specified, the command displays information only about key IDs that are managed by the specified key management. For example, use onboardfor onboard key management.
- [-key-id <text>]- Key Identifier
If this parameter is specified, the command displays information only about the specified key IDs.
- [-key-tag <text>]- Key Tag
If this parameter is specified, the command displays information only about key IDs that have the specified key tags.
- [-key-location <text>]- Key Location
If this parameter is specified, the command displays information only about key IDs that are located on the specified key location. For example, use local-clusterfor onboard key management.
- [-used-by <Key Usage Type>]- Used By
If this parameter is specified, the command displays information only about key IDs that are associated with the specified application usage of the keys. For example, "NSE-AK" would display key IDs only for NSE drives.
- [-restored {yes|no}]- Restored
If this parameter is specified, the command displays information only about key IDs that have the specified value of restored keys. If restored is yes, then the corresponding key is available (normal). If restored isno, use the security key-manager setup command to restore the key. See the man page for security key-manager setup for details.
The following example shows all keys stored in the onboard key manager:
cluster-1::> security key-manager key show
Node: node1
Key Store: onboard
Used By
NSE-AK
    Key ID: 000000000000000002000000000001001bc4c708e2a89a312e14b6ce6d4d49d40000000000000000
NSE-AK
    Key ID: 000000000000000002000000000001005e89099721f8817e65e3aeb68be1bfca0000000000000000
SVM-KEK
    Key ID: 00000000000000000200000000000a0046df92864d4cece662b93beb7f5366100000000000000000
Node: node2
Key Store: onboard
Used By
NSE-AK
NSE-AK
SVM-KEK
6 entries were displayed.
The following example shows a detailed view of all keys stored in the onboard key manager:
cluster-1::> security key-manager key show -detail
Node: node1
Key Store: onboard
Key ID Key Tag         Used By    Stored In                            Restored
       -               NSE-AK     local-cluster                        yes
       -               SVM-KEK    local-cluster                        yes
Node: node2
Key Store: onboard
 PDFs
PDFs
