      network ipspace show
Display IPspace information
Display network IPspaces.
- { [-fields <fieldname>,…]
Specify the fields to be displayed for each IPspace.
- | [-instance ]}
Display all parameters of the IPspace objects.
- [-ipspace <IPspace>]- IPspace name
Display the names of the IPspaces.
- [-ports [node>:<port],…]- Ports
The list of network ports assigned to each IPspace.
- [-broadcast-domains <Broadcast Domain>,…]- Broadcast Domains
The list of broadcast domains that belong to the IPspace.
- [-vservers <vserver name>,…]- Vservers
The list of Vservers assigned to each IPspace.
The following example displays general information about IPspaces.
cluster1::> network ipspace show
IPspace             Vserver List                  Broadcast Domains
Cluster
                    Cluster                       -
Default
                    cluster1, vs1, vs2            br1, br2, br3
2 entries were displayed.
 PDFs
PDFs
