metrocluster configuration-settings interface delete
Delete a MetroCluster interface
The metrocluster configuration-settings interface delete command deletes the network logical interface that was configured on a network port provisioned for MetroCluster.
This command cannot be run if the metrocluster configuration-settings connection connect command has set up the connections between the nodes in a DR group. The metrocluster configuration-settings connection disconnect command must then be run to remove the connections.
The metrocluster configuration-settings commands are run in the following order to remove the MetroCluster over IP configuration:
metrocluster configuration-settings interface delete,
-cluster-name <Cluster name>- Cluster Name-
Use this parameter to specify the name of the local or partner cluster.
-home-node <text>- Home Node-
Use this parameter to specify the home node in the cluster which hosts the interface.
-home-port {<netport>|<ifgrp>}- Home Port-
Use this parameter to specify the home port provisioned for MetroCluster.
The following example shows the deletion of interface in a MetroCluster setup:
clusA::> metrocluster configuration-settings interface delete -cluster-name clusA -home-node A1 -home-port e0f
[Job 271] Job succeeded: Interface Delete is successful.
clusA::> metrocluster configuration-settings interface show
DR Config
Group Cluster Node Network Address Netmask Gateway State
1 clusA A1
Home Port: e0g
10.140.113.215 255.255.192.0 - completed
A2
Home Port: e0f
10.140.113.216 255.255.192.0 - completed
Home Port: e0g
10.140.113.217 255.255.192.0 - completed
clusB B2
Home Port: e0f
10.140.113.249 255.255.192.0 - completed
Home Port: e0g
10.140.113.25 255.255.192.0 - completed
B1
Home Port: e0f
10.140.113.218 255.255.192.0 - completed
Home Port: e0g
10.140.113.248 255.255.192.0 - completed
7 entries were displayed.
clusA::> metrocluster configuration-settings show-status
Cluster Node Configuration Settings Status
clusA
A1 ready for next interface create
A2 ready for connection connect
clusB
B1 ready for connection connect
B2 ready for connection connect
4 entries were displayed.
Output of the command after deleting all the interfaces:
No interfaces exist.
clusA
A1 ready for interface create
A2 ready for interface create
clusB
B1 ready for interface create
B2 ready for interface create
