storage shelf location-led show
Display the Location LED status
The storage shelf location-led show command displays the state of shelf location LED.
[-fields <fieldname>,…] -
If you specify the
[-instance ] -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-shelf-name <text>]- Shelf Name-
Selects the shelves whose shelf-name matches this parameter value.
[-node {<nodename>|local}]- Node Name-
Selects the nodes that match this parameter value.
[-stack-id <integer>]- Stack ID-
Selects the shelves whose stack-id matches this parameter value.
[-shelf-id <integer>]- Shelf ID-
Selects the shelves whose shelf-id matches this parameter value.
[-led-status {on|off}]- Location LED-
Shows the state of the shelf location LED.
The following example shows the state of the shelf location LED for each shelf.
cluster1::> storage shelf location-led show
Shelf Name Stack ID Shelf ID LED Status
8.2 8 2 off
8.3 8 3 off
6.0 6 0 unsupported
8.1 8 1 off
4 entries were displayed.
