job private watch-progress
Watch the progress of a job
The job private watch-progress command displays and periodically updates the progress of a private job. A private job is a job that is associated with a specific node and does not use cluster facilities. You can specify the frequency of the progress updates.
- -node {<nodename>|local}- Node (privilege: advanced)
This specifies the node on which the job is running.
- -id <integer>- Job ID (privilege: advanced)
This specifies the numeric ID of the job whose progress is to be monitored.
- [-vserver <vserver name>]- Owning Vserver (privilege: advanced)
Use this parameter to specify the Vserver with which the paused private job is associated.
- [-interval <integer>]- Refresh Interval (seconds) (privilege: advanced)
This optionally specifies, in seconds, the frequency of the updates.
The following example monitors the progress of the private job that has ID 127 on a node named node1. The progress is updated every 2 seconds.
cluster1::*> job private watch-progress -node node1 -id 127 -interval 2 Queued
 PDFs
PDFs
