vserver vscan on-access-policy delete
Delete an On-Access policy
The vserver vscan on-access-policy delete command deletes an On-Access policy.
-vserver <vserver name>- Vserver-
This parameter specifies the name of the Vserver from which you want to delete an On-Access policy.
-policy-name <Policy name>- Policy-
This parameter specifies the name of the On-Access policy that you want to delete.
The following example deletes an On-Access policy.
cluster1::> vserver vscan on-access-policy delete -vserver vs1 -policy-name test cluster1::> vserver vscan on-access-policy show -vserver vs1 -policy-name test There are no entries matching your query.
