network options switchless-cluster modify
Modify switchless cluster network options
This command sets whether the cluster network is in switchless or switched mode. A switchless cluster is physically formed by connecting two nodes back-to-back, without a switch between them.
[-enabled {true|false}]
- Enable Switchless Cluster-
This parameter specifies whether the switchless cluster is enabled or not. Setting this parameter to
true
enables the switchless cluster.
The following example enables the switchless cluster: cluster1::*> network options switchless-cluster modify -enabled true
