volume qtree statistics-reset
(DEPRECATED)-Reset qtree statistics in a volume
Note: This command does not support FlexGroups and will be deprecated in a future release of Data ONTAP. Use the statistics qtree show command to view qtree statistics.
This command resets qtree statistics for all qtrees in a volume.
-vserver <vserver name>
- Vserver Name-
This specifies the name of the Vserver on which the volume containing the qtree belongs.
-volume <volume name>
- Volume Name-
This specifies the name of the volume containing the qtrees whose statistics you want to reset.
The following example resets statistics for all qtrees on the volume named vol1 on the Vserver named vs0.
cluster1::> volume qtree statistics-reset -vserver vs0 -volume vol1
