vserver cifs domain preferred-dc show
Display a list of preferred domain controllers
The vserver cifs domain preferred-dc show command displays lists of preferred domain controllers by Vserver and domain.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
This parameter specifies the name of the Vserver for which you want to display preferred domain controllers.
[-domain <TextNoCase>] - Fully Qualified Domain Name
This parameter specifies the fully-qualified name of the domain of the domain controllers to display.
[-preferred-dc <InetAddress>,…​] - Preferred Domain Controllers
This parameter specifies a comma-delimited list of IP addresses for domain controllers to display.
The following example displays all preferred domain controllers for all Vservers:
cluster1::> vserver cifs domain preferred-dc show
Vserver        Domain Name                   Preferred Domain Controllers
vs1            example.com                   192.168.0.100, 192.168.0.101
