vserver stop
Stop a Vserver
The vserver stop command stops data access on a Vserver.
-vserver <vserver>- Vserver-
This specifies the name of the Vserver on which the data access is to be stopped. This operation is only supported on a data Vserver.
The name must be of 47 characters length or less. [-foreground {true|false}]- Foreground Process-
This specifies if
vserver stopcommand should be executed in the foreground or background. If you do not enter this parameter, it is set totrue, and the ` vserver stop` command is executed in the foreground.
The following example stops data access on Vserver vs0.example.com in the background.
cluster1::> vserver stop -vserver vs0.example.com -foreground false
