system license show
Display licenses
The ` system license show ` command displays the information about licenses in the system.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-serial-number <text>]- Serial Number-
If you use this parameter, the command displays information only about the licenses that matches the serial number you specify.
[-package <Licensable Package>]- Package-
If you use this parameter, the command displays information only about the specified package.
[-owner <text>]- Owner-
If you use this parameter, the command displays information only about the packages that matches the owner name you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>]- Expiration-
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
[-description <text>]- Description-
If you use this parameter, the command displays information only about the licenses that matches the description you specify.
[-type {license|site|demo|subscr|capacity|capacity-per-term}]- Type-
If you use this parameter, the command displays information only about the licenses that have the license type you specify.
[-legacy {yes|no}]- Legacy-
If you use this parameter, the command displays information only about the licenses that matches the legacy field you specify.
[-customer-id <text>]- Customer ID-
If you use this parameter, the command displays information only about the licenses that have the customer-id you specify.
The following example displays default information about all licensed packages in the cluster:
cluster1::> system license show Serial Number: 1-80-123456 Owner: cluster1 Package Type Description Expiration ----------------- ------- --------------------- -------------------- Base site Cluster Base License - NFS site NFS License - iSCSI site iSCSI License - Serial Number: 1-81-0000000000000001122334455 Owner: node1 Package Type Description Expiration ----------------- ------- --------------------- -------------------- NFS license NFS License - SnapRestore license SnapRestore License - 5 entries were displayed.
