system license show
Display licenses
The ` system license show ` command displays the information about licenses in the system.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-serial-number <text>] - Serial Number
If you use this parameter, the command displays information only about the licenses that matches the serial number you specify.
[-package <Licensable Package>] - Package
If you use this parameter, the command displays information only about the specified package.
[-owner <text>] - Owner
If you use this parameter, the command displays information only about the packages that matches the owner name you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>] - Expiration
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
[-description <text>] - Description
If you use this parameter, the command displays information only about the licenses that matches the description you specify.
[-type {license|site|demo|subscr|capacity|capacity-per-term}] - Type
If you use this parameter, the command displays information only about the licenses that have the license type you specify.
[-legacy {yes|no}] - Legacy
If you use this parameter, the command displays information only about the licenses that matches the legacy field you specify.
[-customer-id <text>] - Customer ID
If you use this parameter, the command displays information only about the licenses that have the customer-id you specify.
The following example displays default information about all licensed packages in the cluster:
cluster1::> system license show
Serial Number: 1-80-123456
Owner: cluster1
Package           Type    Description           Expiration
Base              site    Cluster Base License  -
NFS               site    NFS License           -
iSCSI             site    iSCSI License         -
Serial Number: 1-81-0000000000000001122334455
Owner: node1
NFS               license NFS License           -
SnapRestore       license SnapRestore License   -
5 entries were displayed.
