system license show
Display licenses
The ` system license show ` command displays the information about licenses in the system.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-serial-number <text>]
- Serial Number-
If you use this parameter, the command displays information only about the licenses that matches the serial number you specify.
[-package <Licensable Package>]
- Package-
If you use this parameter, the command displays information only about the specified package.
[-owner <text>]
- Owner-
If you use this parameter, the command displays information only about the packages that matches the owner name you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>]
- Expiration-
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
[-description <text>]
- Description-
If you use this parameter, the command displays information only about the licenses that matches the description you specify.
[-type {license|site|demo|subscr|capacity|capacity-per-term}]
- Type-
If you use this parameter, the command displays information only about the licenses that have the license type you specify.
[-legacy {yes|no}]
- Legacy-
If you use this parameter, the command displays information only about the licenses that matches the legacy field you specify.
[-customer-id <text>]
- Customer ID-
If you use this parameter, the command displays information only about the licenses that have the customer-id you specify.
The following example displays default information about all licensed packages in the cluster:
cluster1::> system license show Serial Number: 1-80-123456 Owner: cluster1 Package Type Description Expiration ----------------- ------- --------------------- -------------------- Base site Cluster Base License - NFS site NFS License - iSCSI site iSCSI License - Serial Number: 1-81-0000000000000001122334455 Owner: node1 Package Type Description Expiration ----------------- ------- --------------------- -------------------- NFS license NFS License - SnapRestore license SnapRestore License - 5 entries were displayed.
