      network port vip show
Display VIP ports
The network port vip show command displays information about VIP ports.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
This parameter selects the VIP ports that match the specified node.
- [-port <netport>]- Network Port
This parameter selects the VIP ports that match the specified port.
- [-ipspace <IPspace>]- IPspace Name
This parameter selects the VIP ports that match the specified IPspace.
The example below shows VIP port v0a is created in IPspace ips on node1.
cluster1::> network port vip show
    Node   VIP Port IPspace
    node1  v0a      ips
 PDFs
PDFs
