lun portset delete
Delete the portset
This command deletes an existing port set. By default, you cannot delete a port set if it is bound to an initiator group. If a port set is bound to an initiator group, you can do one of the following:
specify the
force
option to unbind the port set from the initiator group and delete the port set. -
use the lun igroup unbind command to unbind the port set from the initiator group. Then you can delete the port set.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-portset <text>
- Portset Name-
Specifies the port set you want to delete.
[-f, -force <true>]
- Force-
Forcibly unbinds the port set from the initiator group.
cluster1::> portset delete -vserver vs1 -portset ps1
Deletes port set ps1 on Vserver vs1.
