      system cluster-switch prepare-to-downgrade
Remove unsupported switches in preparation for downgrade
The system cluster-switch prepare-to-downgrade command changes switch information, so that it is compatible with older versions of ONTAP. When executed, it removes cluster switch entries that are not supported in versions earlier than ONTAP 9.1.
cluster1::> system cluster-switch prepare-to-downgrade
