ONTAP commands
security login role delete
Delete an access control role
The security login role delete command deletes an access-control role.
-vserver <Vserver Name> - Vserver
This optionally specifies the Vserver name associated with the role.
-role <text> - Role Name
This specifies the role that is to be deleted.
-cmddirname <text> - Command / Directory
This specifies the command or command directory to which the role has access. To specify the default setting, use the special value "`DEFAULT` ".
The following command deletes an access-control role with the role name readonly and the command access "volume" for Vserver vs.example.com.
cluster1::> security login role delete -role readonly -cmddirname volume -vserver vs.example.com
