ONTAP commands
network interface failover-groups show
Display logical interface failover groups
The network interface failover-groups show command displays information about logical interface failover groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver>] - Vserver Name
Use this parameter to display information only about the logical interface failover groups that have the target Vserver you specify.
[-failover-group <text>] - Failover Group Name
Use this parameter to display information only about the logical interface failover groups you specify.
[-targets [node>:<port],…​] - Failover Targets
Use this parameter to display information only about the logical interface failover groups that have the failover target (physical port, interfacde group, or VLAN) you specify.
[-broadcast-domain <Broadcast Domain>] - Broadcast Domain
Use this parameter to display information only about the logical interface failover groups that have the broadcast domain you specify.
The following example displays information about all logical interface failover groups on a two node cluster.
cluster1::> network interface failover-groups show
                                  Failover
Vserver          Group            Targets
Cluster
                 Cluster
                                  node1:e1a, node1:e2a,
                                  node2:e1a, node2:e2a,
cluster1
                 Default
                                  node1:e0M, node1:e0a,
                                  node1:e0b, node1:e0c,
                                  node1:e0d, node2:e0M,
                                  node2:e0a, node2:e0b,
                                  node2:e0c, node2:e0d
Looking for answers?
Try Doc, our Gen AI Assistant.
