security login rest-role show
Show access control REST roles
The security login rest-role show command displays the following information about access-control roles:
vserver
Role name
api to which the role has access
Access level (none, read-only, or all)
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Selects the roles that match this parameter value.
 [-role <text>]- Role Name-
Selects the roles that match this parameter value. If this parameter and the
-apiparameter are both used, the command displays detailed information about the specified access-control role. [-api <text>]- api path-
-roleparameter are both used, the command displays detailed information about the specified access-control role. [-access <Access>]- Access Level-
The example below displays information about all access-control roles:
cluster1::> security login rest-role show Role Access Vserver Name API Level ---------- ------------- ----------- ----------- vs vsadmin /api none cluster1 readonly /api/storage none
