vserver audit delete
Delete audit configuration
The vserver audit delete command deletes the audit configuration for a Vserver.
-vserver <vserver name>- Vserver-
This parameter specifies the name of the Vserver associated with the audit configuration to be deleted.
[-force <true>]- Force Delete (privilege: advanced)-
This parameter is used to forcibly delete the audit configuration. By default the setting is
false.
The following example deletes the audit configuration for Vserver vs1.
cluster1::> vserver audit delete -vserver vs1
