ONTAP commands
volume flexcache sync-properties
Sync FlexCache volume properties with its origin
The volume flexcache sync-properties command is used to sync a FlexCache volumes properties with its origin volume.
Note This command only needs to be used when there was a failure to sync properties from the origin of a FlexCache volume to the FlexCache volume.
-vserver <vserver name> - Vserver Name (privilege: advanced)
This specifies the Vserver on which the FlexCache volume is located.
-volume <volume name> - Volume Name (privilege: advanced)
This specifies the FlexCache volume whose properties need to be synced with its origin of a FlexCache volume.
cluster1::> flexcache sync-properties -volume fc1 -vserver vs34
          (volume flexcache sync-properties)
