ONTAP commands
system services ndmp modify
(DEPRECATED)-Modify NDMP service configuration
Note This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "vserver services ndmp modify " command.
The system services ndmp modify command allows you to modify the NDMP configurations for a node in the cluster. One or more of the following configurations can be modified:
  • Enable/disable NDMP service
  • Enable/disable sending the NDMP password in clear text. Note that MD5 authentication mode is always enabled.
  • NDMP user ID
-node {<nodename>|local} - Node
This specifies the node whose NDMP configuration is to be modified.
[-enable {true|false}] - NDMP Service Enabled
This optionally specifies whether NDMP is enabled on the node. The default setting is true .
[-clear-text {true|false}] - Allow Clear Text Password
This optionally specifies whether the NDMP password can be sent in clear text. The default setting is true .
[-user-id <text>] - NDMP User ID
This optionally specifies the ID of the NDMP user.
The following example modifies the NDMP configuration on a node named node1. The configuration enables NDMP, disables sending the password in clear text, and specifies an NDMP user named ndmp:
cluster1::> system services ndmp modify -node node1 -enable true
     -clear-text false -user-id ndmp
