statistics preset show
Display information about Performance Presets
Displays information about performance preset configurations.
[-fields <fieldname>,…]
Selects which performance preset attributes to display.
[-instance ]
Shows details of all attributes of performance preset configuration.
[-preset <text>]
- Preset Name-
Selects the performance presets that match the specified preset name.
[-comment <text>]
- Preset Description-
Selects the performance presets that match the specified comment.
[-privilege <PrivilegeLevel>]
- Preset Privilege Level-
Selects the performance presets that are available with the specified privilege.
[-is-read-only {true|false}]
- Is Preset Read-Only?-
Selects the performance presets that are read-only (true) or are not read-only (false). Read-only presets cannot be modified.
[-store <text>]
- Name of Store Where Data is Saved-
Selects the store where data is saved.
cluster1::*> statistics preset show Preset Name Privilege Read-Only Comment ------------------- ---------- --------- -------------------------------------- aggregate_overview admin true This preset configuration is used by statistics aggregate show command. Provides overview of aggregate object. disk_overview advanced true This preset configuration is used by statistics disk show command. Provides overview of disk object. fcp_port_overview admin true This preset configuration is used by statistics port fcp show command. Provides overview of fcp port object. flash_pool_overview admin true This preset configuration is used by statistics cache flash-pool show command. Provides overview of flash pool object. [...]
