security certificate delete
Delete an Installed Digital Certificate
This command deletes an installed digital security certificate.
- -vserver <Vserver Name>- Name of Vserver
This specifies the Vserver that contains the certificate.
- -common-name <FQDN or Custom Common Name>- FQDN or Custom Common Name
This specifies the desired certificate name as a fully qualified domain name (FQDN) or custom common name or the name of a person. The supported characters, which are a subset of the ASCII character set, are as follows: -
Letters a through z, A through Z
Numbers 0 through 9
Asterisk (*), period (.), underscore (_) and hyphen (-)
 The common name must not start or end with a "-" or a ".". The maximum length is 253 characters.
- [-serial <text>]- Serial Number of Certificate
This specifies the certificate serial number.
- -ca <text>- Certificate Authority
This specifies the certificate authority (CA).
- -type <type of certificate>- Type of Certificate
This specifies the certificate type. Valid values are the following: -
server- includes server certificates and intermediate certificates
root-ca- includes a self-signed digital certificate to sign other certificates by acting as a certificate authority (CA)
client-ca- includes the public key certificate for the root CA of the SSL client. If this client-ca certificate is created as part of a root-ca, it will be deleted along with the corresponding deletion of the root-ca.
server-ca- includes the public key certificate for the root CA of the SSL server to which Data ONTAP is a client. If this server-ca certificate is created as part of a root-ca, it will be deleted along with the corresponding deletion of the root-ca.
client- includes a public key certificate and private key to be used for Data ONTAP as an SSL client
- [-subtype <kmip-cert>]- (DEPRECATED)-Certificate Subtype
This parameter has been deprecated in ONTAP 9.6 and may be removed in a future release of Data ONTAP. This specifies a certificate subtype. This optional parameter can have an empty value (the default). The only valid value is as follows: -
kmip-cert- this is a Key Management Interoperability Protocol (KMIP) certificate
- [-cert-name <text>]- Unique Certificate Name
This specifies the system's internal identifier for the certificate. It is unique within a Vserver.
This example deletes a root-ca type digital certificate for a Vserver named vs0 in a company named www.example.com with serial number 4F57D3D1.
cluster1::> security certificate delete -vserver vs0 -common-name `_www.example.com_` -ca `_www.example.com_` -type root-ca -serial 4F57D3D1
 PDFs
PDFs
