ONTAP commands
vserver export-policy create
Create a rule set
The vserver export-policy create command creates an export policy. You can use the vserver export-policy rule create command to add rules to a policy. Each cluster has an empty default export policy with the ID 0. This default export policy does not contain any rules. You cannot delete the default export policy, but you can rename or modify it.
-vserver <vserver name> - Vserver
This parameter specifies the Vserver on which you want to create the export policy.
-policyname <export policy name> - Policy Name
This parameter specifies the export policy that you want to create.
The following example creates an export policy named read_only_expolicy on a Vserver named vs0:
vs1::> vserver export-policy create -vserver vs0 -policyname read_only_expolicy
Looking for answers?
Try Doc, our Gen AI Assistant.
