storage tape online
Bring a tape drive online
This command brings a specified tape drive online.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node to which the tape drive is attached.
-device-id <text>
- Tape Drive Device ID -
Use this parameter to specify the device ID of the tape drive that needs to be brought online.
-name <text>
- Tape Drive Device Name } -
Use this parameter to specify the device name of the tape drive that needs to be brought online. The format of the device
-name
name includes a prefix to specify how the tape cartridge is handled and a suffix to describe the density of the tape. The prefix suggests 'r', 'nr' or 'ur' for rewind, no rewind, or unload/reload and a suffix shows density of 'l', 'm', 'h' or 'a'. For example, a tape device name for this operation might have the form "nrst8m" were 'nr' is the 'no rewind' prefix, 'st8' is the alias-name and 'm' is the tape density. You can use the 'storage tape show -device-names' command to find more information about device names of tape drives attached to a node.
The following example brings the tape drive with device id sw4:2.126L4 attached to the node, cluster1-01, online.
cluster1::> storage tape online -node cluster1-01 -device-id sw4:2.126L4
