storage bridge config-dump collect
Retrieve and save bridge dumpconfiguration
The storage bridge config-dump collect command retrieves a dumpconfiguration file from a storage bridge.
-bridge <text> - Bridge Name
Use this parameter to retrieve a dumpconfiguration file from the specified storage bridge.
The following example retrieves a dumpconfiguration file from storage bridge ATTO_FibreBridge7500N_1:
cluster1::*> storage bridge config-dump collect -bridge ATTO_FibreBridge7500N_1
[Job 883] Job is queued: Collect the dumpconfiguration file from bridge "ATTO_FibreBridge7500N_1".
cluster1::*>
