ONTAP commands
vserver audit enable
Enable auditing
The vserver audit enable command enables auditing for a Vserver.
Note Events on FlexGroup volumes are not emitted to the audit log.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver for which auditing is to be enabled. The Vserver audit configuration must already exist.
[-force <true>] - Force Enable (privilege: advanced)
This parameter is used to ignore errors while enabling auditing.
The following example enables auditing for Vserver vs1:
cluster1::> vserver audit enable -vserver vs1
