      cluster peer modify-local-name
Modify the local name for a cluster peer
The cluster peer modify-local-name command modifies the local name for a remote cluster. The new local name must be unique among all the local names for the remote clusters with which this cluster is peered.
- -name <text>- Cluster Peer Name
Use this parameter to specify the existing local name for a peer cluster.
- -new-name <Cluster name>- Cluster Peer Local Name
Use this parameter to specify the new local name of the peer cluster. The new local name must conform to the same rules as a cluster name.
cluster2::> cluster peer modify-local-name -name cluster1 -new-name cluster1A
 PDFs
PDFs
