system node image package delete
Delete a software package
The delete command will delete the specified software package.
-node {<nodename>|local} - Node
The package will be deleted from the repository belonging to the node specified with this parameter. The local node is used as the default if this parameter is omitted.
-package <text> - Package File Name
This parameter specifies the package to be deleted.
::> system image package delete image.tgz
1 entry was deleted.
