      storage port enable
Enable a storage port
The storage port enable command enables a specified storage port.
- -node {<nodename>|local}- Node
Use this parameter to specify the node on which the port resides.
- -port <text>- Port
Use this parameter to specify the port that needs to be enabled.
The following example enables port 0a on node node1:
cluster1::> storage port enable -node node1 -port 0a
 PDFs
PDFs
