storage tape show-supported-status
Displays the qualification and supported status of tape drives
This command displays the supported and qualification status of all tape drives recognized by Data ONTAP attached to a node in the cluster. This includes nonqualified tape drives. Such tape drives do not have a Tape Configuration File (TCF) on the storage system. A nonqualified tape drive can be used if the tape drive emulates a qualified tape drive or if the appropriate TCF for the nonqualified tape drive is downloaded from the NetApp Support Site to the storage system.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the tape drives that match this parameter value.
[-tape-drive <text>]- Tape Drive Name-
[-is-supported {true|false}]- Tape Drive Supported-
[-status <text>]- Supported Status-
The following example displays support and qualification status of tape drives recognized by Data ONTAP. The command also identifies tape drives attached to the node that are nonqualified (not supported).
cluster1::> storage tape show-supported-status
Node: Node1
Is
Tape Drive Supported Support Status
sw4:2.126L6 false Nonqualified tape drive
Hewlett-Packard C1533A true Qualified
Hewlett-Packard C1553A true Qualified
Hewlett-Packard Ultrium 1 true Qualified
Sony SDX-300C true Qualified
Sony SDX-500C true Qualified
StorageTek T9840C true Dynamically Qualified
StorageTek T9840D true Dynamically Qualified
Tandberg LTO-2 HH true Dynamically Qualified
drives selected by tape-drive. The command identifies the supported
status of the selected tape drive.
cluster1::> storage tape show-supported-status -tape-drive "Sony SDX-300C"
Node: Node1
Is
Tape Drives Supported Support Status
