storage switch remove
Remove a back-end switch from monitoring
The storage switch remove enables you to remove FC back-end switches that were previously added for SNMP monitoring.
-switch-name <text>- FC Switch Name-
This parameter specifies the name of the back-end switch added for monitoring.
The following command removes 'Cisco_10.226.197.34' switch from monitoring:
cluster1::> storage switch show
Symbolic Is Monitor
Switch Name Vendor Model Switch WWN Monitored Status
Cisco_10.226.197.34
mcc-cisco-8Gb-fab-4
Cisco DS-C9148-16P-K9
2000547fee78f088 true ok
mcc-cisco-8Gb-fab-1
mcc-cisco-8Gb-fab-1
Cisco - - false -
mcc-cisco-8Gb-fab-2
mcc-cisco-8Gb-fab-2
Cisco - - false -
mcc-cisco-8Gb-fab-3
mcc-cisco-8Gb-fab-3
Cisco - - false -
4 entries were displayed.
cluster1::> storage switch remove -switch-name Cisco_10.226.197.34
Symbolic Is Monitor
mcc-cisco-8Gb-fab-4
mcc-cisco-8Gb-fab-4
Cisco
- - false -
mcc-cisco-8Gb-fab-1
mcc-cisco-8Gb-fab-1
Cisco - - false -
mcc-cisco-8Gb-fab-2
mcc-cisco-8Gb-fab-2
Cisco - - false -
mcc-cisco-8Gb-fab-3
mcc-cisco-8Gb-fab-3
Cisco - - false -
cluster1::>
