      storage switch remove
Remove a back-end switch from monitoring
The storage switch remove enables you to remove FC back-end switches that were previously added for SNMP monitoring.
- -switch-name <text>- FC Switch Name
This parameter specifies the name of the back-end switch added for monitoring.
The following command removes 'Cisco_10.226.197.34' switch from monitoring:
cluster1::> storage switch show
                Symbolic                                     Is        Monitor
    Switch      Name     Vendor  Model      Switch WWN       Monitored Status
    Cisco_10.226.197.34
                mcc-cisco-8Gb-fab-4
                         Cisco   DS-C9148-16P-K9
                                            2000547fee78f088 true      ok
    mcc-cisco-8Gb-fab-1
                mcc-cisco-8Gb-fab-1
                         Cisco   -          -                false     -
    mcc-cisco-8Gb-fab-2
                mcc-cisco-8Gb-fab-2
                         Cisco   -          -                false     -
    mcc-cisco-8Gb-fab-3
                mcc-cisco-8Gb-fab-3
                         Cisco   -          -                false     -
    4 entries were displayed.
cluster1::> storage switch remove -switch-name Cisco_10.226.197.34
                Symbolic                                     Is        Monitor
    mcc-cisco-8Gb-fab-4
                mcc-cisco-8Gb-fab-4
                         Cisco
                                 -          -                false     -
    mcc-cisco-8Gb-fab-1
                mcc-cisco-8Gb-fab-1
                         Cisco   -          -                false     -
    mcc-cisco-8Gb-fab-2
                mcc-cisco-8Gb-fab-2
                         Cisco   -          -                false     -
    mcc-cisco-8Gb-fab-3
                mcc-cisco-8Gb-fab-3
                         Cisco   -          -                false     -
cluster1::>
 PDFs
PDFs
